[GRASS-user] g.extension (e.g. to install i.landsat.toar)
    Nick Jachowski
    njachowski at gmail.com
    Wed Oct 27 10:02:16 EDT 2010
I got the latest version of GRASS 6.4.1svn running (from the binaries), and
I have a new error message when I try to use g.extension.
GRASS 6.4.1svn (10.27):~ > g.extension i.landsat.toar
Fetching <i.landsat.toar> from GRASS-Addons SVN (be patient)...
A    i.landsat.toar/landsat_set.c
A    i.landsat.toar/local_proto.h
A    i.landsat.toar/main.c
A    i.landsat.toar/description.html
A    i.landsat.toar/landsat.c
A    i.landsat.toar/earth_sun.c
A    i.landsat.toar/landsat.h
A    i.landsat.toar/landsat_met.c
A    i.landsat.toar/Makefile
A    i.landsat.toar/earth_sun.h
 U   i.landsat.toar
Checked out revision 44052.
Compiling <i.landsat.toar>...
mkdir -p
/home/neteler/grass64_svn_relbranch_bin_snapshot/grass64_relbranch/bin.x86_64-unknown-linux-gnu
mkdir -p
/home/neteler/grass64_svn_relbranch_bin_snapshot/grass64_relbranch/dist.x86_64-unknown-linux-gnu/include/grass
mkdir -p
/home/neteler/grass64_svn_relbranch_bin_snapshot/grass64_relbranch/dist.x86_64-unknown-linux-gnu/lib
mkdir -p
/home/neteler/grass64_svn_relbranch_bin_snapshot/grass64_relbranch/dist.x86_64-unknown-linux-gnu/bin
mkdir -p
/home/neteler/grass64_svn_relbranch_bin_snapshot/grass64_relbranch/dist.x86_64-unknown-linux-gnu/etc
mkdir -p
/home/neteler/grass64_svn_relbranch_bin_snapshot/grass64_relbranch/dist.x86_64-unknown-linux-gnu/driver
mkdir -p
/home/neteler/grass64_svn_relbranch_bin_snapshot/grass64_relbranch/dist.x86_64-unknown-linux-gnu/driver/db
mkdir -p
/home/neteler/grass64_svn_relbranch_bin_snapshot/grass64_relbranch/dist.x86_64-unknown-linux-gnu/fonts
test -d OBJ.x86_64-unknown-linux-gnu || mkdir -p
gcc
-I/home/neteler/grass64_svn_relbranch_bin_snapshot/grass64_relbranch/dist.x86_64-unknown-linux-gnu/include
 -g -Wall -Werror-implicit-function-declaration -fno-common
-DPACKAGE=\""grassmods"\"
-o OBJ.x86_64-unknown-linux-gnu/earth_sun.o -c earth_sun.c
gcc
-o OBJ.x86_64-unknown-linux-gnu/landsat.o -c landsat.c
landsat.c:4:23: error: grass/gis.h: No such file or directory
landsat.c: In function ‘lsat_bandctes’:
landsat.c:133: error: implicit declaration of function ‘G_verbose_message’
make: *** [OBJ.x86_64-unknown-linux-gnu/landsat.o] Error 1
ERROR: Compilation failed, sorry. Please check above error messages.
Do I have to install GRASS from source for g.extension to work?
Thanks,
Nick
On Sun, Oct 24, 2010 at 9:56 PM, Nick Jachowski <njachowski at gmail.com>wrote:
> Thanks for your help Markus.
> I am now trying to use g.extension with GRASS 6.5.svn and GRASS 7.0.svn on
> Ubuntu 10.10, however when I start either versions of GRASS and try to open
> a new location (using the wxPython gui) I get the following error:
> > g.proj: error while loading shared libraries: libgdal1.5.0.so.1: cannot
> open shared object file: No such file or directory
> I searched for libgdal and found that I have libgdal1.6.0.so.1 at
> ./usr/lib/libgdal1.6.0.so.1
> I don't care whether or not I get GRASS working on this OS or even what
> version of GRASS I get to work.  I am just interested in the easiest way to
> use g.extension to be able to use the i.landsat.toar addon.  Is there a
> flavour of linux that is particularly easy to use when it comes to GRASS?
> And would you recommend GRASS 6.4.0, 6.5, or 7.0 to get g.extension to
> work?
> Any help is appreciated, thanks!
> Nick
> On Fri, Oct 22, 2010 at 12:09 PM, Markus Neteler <neteler at osgeo.org>wrote:
>> On Fri, Oct 22, 2010 at 4:20 PM, Nick Jachowski <njachowski at gmail.com>
>> wrote:
>> > I'm trying to get the grass add-on i.landsat.toar to work using
>> g.extension,
>> > and I've had many problems.  I had been trying it on opensuse 11.3 and I
>> > installed various versions of grass from source, but they all had
>> problems
>> > and did not work.
>> You mean that GRASS (which version) did not work or that g.extension
>> within
>> it failed? Note that there is a known bug for g.extension usage in the
>> Makefile
>> system due to a wrong path which also manifests in OpenSuse.
>> > I've almost given up, and now I am running grass on
>> > poseidon linux (ubuntu base) which came preinstalled with Grass 6.4ORC5.
>> (that's fairly old...)
>> > My question is: what is the easiest, most pain-free way to get
>> g.extension to
>> > work?  What linux flavour should I be using (and is 32-bit or 64-bit
>> > better)?  Which GRASS version number?  Do I need to install from source?
>> It would be needed to fix for many platforms this bug:
>> http://trac.osgeo.org/grass/ticket/620
>> In general, please use 6.4.0 (or 6.4.svn).
>> > If I can't get g.extension to work properly are there any workarounds
>> such
>> > as running it as bash script?
>> It needs to be compiled. You can manually fix the path in
>> include/Make/Platform.make (see above ticket), then g.extension
>> should work. Yesterday I made an attempt to also fix the
>> system wide installation (in GRASS 6.5) which might be
>> backported.
>> Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20101027/79371bff/attachment-0001.html
