[GRASS-user] g.extension not working
Hamish
hamish_b at yahoo.com
Thu Sep 2 02:44:53 EDT 2010
> > Otherwise, if you installed grass as root (make install as root), you
> > most probably also have to install addons as root.
Markus Neteler wrote:
> Perhaps we need to add some sudo magic...?
will that work with MSys? (does g.extension work at all with standalone
WinGrass?)
addons should really be installed to $GRASS_ADDON_PATH, right? not $GISBASE
(typically that will be read-only if GRASS came from a package; GISBASE is
the default for prefix= currently).
maybe have a test at the start of the script to see if GRASS_ADDON_PATH
exists and if it does use that as the default for prefix= instead of GISBASE? (n.b. $GRASS_ADDON_PATH/ replaces to $GISBASE/bin, not $GISBASE/)
either way, the short term solution seems to be another paragraph in the
help page to explain all this.
Hamish
ps- I suspect 'svn commit' uploaded a bit more than you planned in this one:
https://trac.osgeo.org/grass/changeset/43379
