[GRASS-user] Re: d.mon and monitor frames
Damian M maddalena at nc.rr.com
Sat Sep 4 14:03:12 EDT 2010
Thank you for your reply.
I am using the PNG monitor as follows:
    os.environ['GRASS_WIDTH'] = '2000'
    os.environ['GRASS_HEIGHT'] = '1600'
    os.environ["GRASS_TRUECOLOR"] = "TRUE"
    os.putenv('GRASS_PNGFILE', outFileName+".png")
    grass.run_command("d.mon", start="PNG")
   grass.run_command("d.mon", stop="PNG")
View this message in context: http://osgeo-org.1803224.n2.nabble.com/d-mon-and-monitor-frames-tp5496890p5498901.html
Sent from the Grass - Users mailing list archive at Nabble.com.
