[GRASS-user] d.mon and monitor frames
Sat Sep 4 17:04:54 EDT 2010
Markus Neteler wrote:
> > In 7.0, you can use the GRASS_FRAME environment variable to
> > specify the frame for a command, but there isn't any equivalent in
> > 6.x.
> Please suggest a text snippet for
> lib/init/variables.html
It's actually documented for the individual drivers, although it's
implemented by the display library rather than any driver (or the
driver library).
