On Sat, Sep 4, 2010 at 5:28 PM, Glynn Clements <glynn at gclements.plus.com> wrote: > In 7.0, you can use the GRASS_FRAME environment variable to > specify the frame for a command, but there isn't any equivalent in > 6.x. Please suggest a text snippet for lib/init/variables.html Markus
