[GRASS-user] Importing a Scanned Map
kapo coulibaly
kmcoulib at gmail.com
Sun Sep 5 11:01:10 EDT 2010
What format is the map in?
On Sun, Sep 5, 2010 at 10:50 AM, David Kindem <dkindem at gmail.com> wrote:
> Hello,
> I am trying to import a raster map using r.in.gdal. The map was previously
> georeferenced in Q-GIS. When I run r.in.gdal, I receive the message that
> the projection of dataset does not appear to match current location.
> I used the location parameter to create a new location for the scanned map.
> When I attempted to re-project the map from my new location into my
> intended GRASS location, I received the following error:
> Unable to get projection info of input map.
> Looking at the projection information, the projection for the scanned map
> and for my GRASS location match, with the exception of the cellhd.proj
> parameter. The scanned map's cellhd.proj = 0 (unreferenced/unknown).
> I'm not familiar with the function of the cellhd.proj. Could someone shed
> some light on how I might be able to resolve the issue?
> Thanks,
> Dave
> David Kindem
> Grand Haven, MI
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100905/4995879d/attachment.html
