[GRASS-user] Still having problems with d.vect.thematic
Omar Bautista González
omarbautistag at gmail.com
Sun Sep 5 16:07:18 EDT 2010
Hello:
I reported before, maybe 2 years ago, about a problem with
d.vect.thematic. I'm trying to use but I'm not having success. I just
have that problem in a Netbook Remix version of ubuntu. On a ubuntu
desktop version (an older one) everything is fine with
d.vect.thematic. I attach an output file that maybe can help to assess
the problem.
Now I'm using GRASS 6.4.0RC6 (2010) on Ubuntu 10.04 LTS - "Lucid Lynx" version.
Regards,
- Coordinador de Investigación para el Desarrollo,
Diseño, Monitoreo y Evaluación
Visión Mundial República Dominicana
- Colaborador en investigación social del movimiento del software
libre en República Dominicana
d.vect.thematic -s map=JCE_M2006 type=area column=RD_ALIANZA layer=1 icon=basic/circle size=5 maxsize=20 nint=4 pointcolor=255:0:0 linecolor=0:0:0 startcolor=255:0:0 endcolor=0:0:255 themetype=graduated_colors monitor=none themecalc=interval colorscheme=blue-red
Segmentation fault
awk: (FILENAME=- FNR=1) fatal: se intentó una división por cero
Thematic map legend for column RD_ALIANZA of map JCE_M2006
Value range: -
Mapped by 4 intervals of
Color(R:G:B) Value
0:0:255 -
PNG: GRASS_TRUECOLOR status: TRUE
PNG: collecting to file: /home/omar/grassdata/MapeosElectorales/user1/.tmp/omar-laptop/2399.0.ppm,
GRASS_WIDTH=642, GRASS_HEIGHT=482
DBMI-DBF driver error:
SQL parser error: syntax error, unexpected AND processing 'and'
in statement:
SELECT cat FROM JCE_M2006 WHERE RD_ALIANZA >= and RD_ALIANZA<=
Error in db_open_select_cursor()
85:0:170 -
in statement:
SELECT cat FROM JCE_M2006 WHERE RD_ALIANZA > and RD_ALIANZA<=
170:0:85 -
in statement:
255:0:0 -
in statement:
g.pnmcomp in=2399.4.ppm mask=2399.4.pgm opacity=1.0 background=255:255:255 width=642 height=482 output=2399.1.ppm
