[GRASS-user] Importing a Scanned Map
David Kindem
dkindem at gmail.com
Mon Sep 6 12:13:41 EDT 2010
Thanks Maris, that did the trick.
Dave
David Kindem
On Sep 5, 2010, at 1:48 PM, Maris Nartiss wrote:
> You don't need to create different location if that GeoTIFF has same
> coordinate system as Your current GRASS location. Just use r.in.gdal
> override flag to import it without checking coordinate system match.
> Remember - source and destination MUST have identical coordinate
> systems (except for extent).
> Maris.
> 2010/9/5, kapo coulibaly <kmcoulib at gmail.com>:
>> I believe the wld is a world file, all it has is the coordinate
>> but not the
>> projection infos (not sure about the xml file though). I would
>> suggest you
>> create a dummy GRASS mapset with the projection your tif file was
>> georeferenced at, then use r.proj to import it in your intended
>> location.
>> let me know if I missed the point you were trying to make.
>> On Sun, Sep 5, 2010 at 11:20 AM, David Kindem <dkindem at gmail.com>
>> wrote:
>>> The file is a .tif file with two associated files, a .wld and a
>>> tif.aux.xml.
>>> Dave
>>> David Kindem
>>> On Sep 5, 2010, at 11:01 AM, kapo coulibaly wrote:
>>> What format is the map in?
>>> On Sun, Sep 5, 2010 at 10:50 AM, David Kindem <dkindem at gmail.com>
>>> wrote:
>>>> Hello,
>>>> I am trying to import a raster map using r.in.gdal. The map was
>>>> previously georeferenced in Q-GIS. When I run r.in.gdal, I
>>>> receive the
>>>> message that the projection of dataset does not appear to match
>>>> current
>>>> location.
>>>> I used the location parameter to create a new location for the
>>>> scanned
>>>> map. When I attempted to re-project the map from my new
>>>> location into my
>>>> intended GRASS location, I received the following error:
>>>> Unable to get projection info of input map.
>>>> Looking at the projection information, the projection for the
>>>> scanned map
>>>> and for my GRASS location match, with the exception of the
>>>> cellhd.proj
>>>> parameter. The scanned map's cellhd.proj = 0 (unreferenced/
>>>> unknown).
>>>> I'm not familiar with the function of the cellhd.proj. Could
>>>> someone
>>>> shed
>>>> some light on how I might be able to resolve the issue?
>>>> Thanks,
>>>> Dave
>>>> David Kindem
>>>> Grand Haven, MI
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100906/d6b1bd6e/attachment.html
