[GRASS-user] lots of "The application failed to initialize properly" in 6.4.0 on Windows
Luigi Ponti lponti at inbox.com
Sun Sep 12 20:13:58 EDT 2010
Hi there,
Not sure this is related -- sorry if I should have started a new thread.
I have a WinGRASS-6.4.SVN daily build of last May 29 installed in
"C:/Program Files" on Windows 7, and have been running a set of GRASS
shell scripts no problem under this setup. Now I have installed also
WinGRASS-6.4.0-1, and running the same scripts brings up some issues.
In particular, it seems that 6.4.0-1 has trouble deleting vectors via
g.mremove, which also Maciek reported as problematic and that is why I
replied to the present thread.
For example, a cleanup subroutine in a script includes the following
command:
    g.mremove -f vect=map*
that in 6.4.SVN works fine:
    Removing vector <mapBloomday_Olive_11set10_Avg>
while in 6.4.0-1 doesn't:
    ATTENZIONE: Unable to delete file
'C:\cygwin\home\andy/latlong/luigi/vector/mapBloomday_Olive_11set10_Avg/hist'
    ATTENZIONE: couldn't be removed
    ATTENZIONE: <mapBloomday_Olive_11set10_Avg> nothing removed
and it fails to delete three more vectors the same way. However, rasters
do get deleted.
In my %PATH%, I see no sign of GDAL.
I do have two versions of winGRASS around, but for that matter also a
Cygwin version and an OSGeo4W one.
(Unrelated: is there a way to get GRASS messages 100% in English while
working in an Italian locale?)
Regards,
Luigi
> ------------------------------ Message: 2 Date: Sat, 11 Sep 2010
> 20:38:41 +0100 From: Glynn Clements <glynn at gclements.plus.com>
> Subject: Re: [GRASS-user] lots of "The application failed to
> initialize properly" in 6.4.0 on Windows To: Maciej Sieczka
> <msieczka at sieczka.org> Cc: grass-user <grass-user at lists.osgeo.org>,
> GRASS developers list <grass-dev at lists.osgeo.org> Message-ID:
> <19595.56001.390451.709185 at cerise.gclements.plus.com> Content-Type:
> text/plain; charset=us-ascii Maciej Sieczka wrote:
>> > Lots of commands (e.g. g.proj, g.region, g.remove)
> That list looks suspiciously like "programs which use GDAL".
> You might want to check whether there are other versions of GDAL on
> your system, particularly if they are in %PATH%.
> -- Glynn Clements <glynn at gclements.plus.com
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100913/264d1729/attachment.html
