[GRASS-user] Estimating Albedo from Landsat
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Sun Sep 12 20:35:29 EDT 2010
Daniel Victoria:
> I haven't tryed i.landsat.toar addon but from what I read in the wiki
> (http://grass.osgeo.org/wiki/Atmospheric_correction) I could either
> use i.landsat.toar or a DN - Radiance conversion formula that is
> given...
> Will try to recalculate the images, I might have done something wrong
Hi Daniel!
Did you finally used i.landsat.toar for the Landsat5 - TM bands?
I am trying to use the module on the LT51830332007248MOR00 image(s) and have
several (expected) problems, like:
(note that the metadata file I downloaded via GLOVis has a ".meta" extension)
1. the "LT51830332007248MOR00.meta" isn't read correctly or the module is
looking for a string other than the "date_acquired = 20070905" string which is
the only "date-string" included in the ".meta" file
2. does not recognize the solar elevation value
(the above "cases" are mentioned in the manual, so manual feed is required
here)
3. after manually providing the "solar_elevation" and the "product_date" and
using the "-v" flag, some random (?) segfaults occur.
4. without the "-v" flag it runs but seems to take too much time? OK, the
image set is large ( 7654 cols x 7127 rows x 7 bands). --- Is it really taking
so long or is there something wrong?
Nikos
