[GRASS-user] wingrass7 start and location
Pham Thy
maithy.osgeo at gmail.com
Wed Sep 15 22:50:04 EDT 2010
Pham Thy wrote:
> Dear Helmut,
> Could you guide me more clearly? I donnot understand so well. Because
> I tried to follow the guide to self compile "GRASS on MS-Windows" and
> "GRASS windows native binary building", but they did not work exactly
> the step in guide. For example: 1st step install MSYS, but it
> automatic installed MinGW same with step 2...
> Could you help me to teach me how install and run successfully GRASS
> 7.0 (in ogeo4w or wingrass is ok)?
> Thank you in advance.
> Mai Thy
> Helmut Kudrnovsky wrote:
>>> so maybe the WinGrass7-installer built against gdal17 should be
>>> adapted in that way to adopt gdal17 as the regular version
>> of gdal?
>> I've opened a ticket for this, see:
>> http://trac.osgeo.org/grass/ticket/1157
>> best regards
>> Helmut
>> ___________________________________________________________
>> GRATIS: Spider-Man 1-3 sowie 300 weitere Videos!
>> Jetzt kostenlose Movie-FLAT freischalten! http://movieflat.web.de
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Could you guide me more clearly? I donnot understand so well. Because I
tried to follow the guide of "GRASS on MS-Windows" and "GRASS windows
native binary building", but they did not work exactly the step in it.
For example: 1st step install MSYS, but it automatic installed MinGW
same with step 2...
Could you teach me how install easiest way and run successfully GRASS
7.0 because I need i.atcorr for IKONOS?
Thy
