[GRASS-user] Re: which file do I use? .adf files
    stephen sefick
    ssefick at gmail.com
    Fri Sep 17 06:45:41 EDT 2010
Thanks for all of your help.  The metadata is of no help, already been
down that road.  This is more of a arc file structure problem...
On Fri, Sep 17, 2010 at 3:50 AM, Sylvain Maillard
<sylvain.maillard at gmail.com> wrote:
> have you take a look in the metadata.xml file? regarding the name i guess
> you could find usefull information inside ...
> Sylvain
> 2010/9/17 Hermann Peifer <peifer at gmx.eu>
>> I guess you want to run r.in.gdal, or something. So you could follow this
>> advice:
>> > To open the coverage select the coverage directory,
>> > or an .adf file (such as hdr.adf) from within it.
>> http://www.gdal.org/frmt_various.html#AIG
>> Hermann
>> On 17/09/2010 02:33, stephen sefick wrote:
>>> I know that I need to use a .adf file, but which one?  Is there a way
>>> to find out?  These are all in a file folder that is supposed to
>>> contain a 1_foot LIDAR dem.
>>> dblbnd.adf
>>> sta.adf
>>> w001001x.adf
>>> z001003.adf
>>> z001005x.adf
>>> hdr.adf
>>> vat.adf
>>> z001001.adf
>>> z001003x.adf
>>> hillshd_10m
>>> w001000.adf
>>> z001001x.adf
>>> z001004.adf
>>> metadata.xml
>>> w001000x.adf
>>> z001002.adf
>>> z001004x.adf
>>> prj.adf
>>> w001001.adf
>>> z001002x.adf
>>> z001005.adf
>>> thanks for all of your help,
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Stephen Sefick
| Auburn University                                   |
| Department of Biological Sciences           |
| 331 Funchess Hall                                  |
| Auburn, Alabama                                   |
| 36849                                                    |
|___________________________________|
| sas0025 at auburn.edu                             |
| http://www.auburn.edu/~sas0025             |
Let's not spend our time and resources thinking about things that are
so little or so large that all they really do for us is puff us up and
make us feel like gods.  We are mammals, and have not exhausted the
annoying little problems of being mammals.
                                -K. Mullis
"A big computer, a complex algorithm and a long time does not equal science."
                              -Robert Gentleman
