[GRASS-user] Two questions re 6.4 and OSX 10.4
William Kyngesburye
woklist at kyngchaos.com
Fri Sep 17 09:47:01 EDT 2010
--with-proj --with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include --with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib --with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj
On Sep 17, 2010, at 3:48 AM, Richard Chirgwin wrote:
> William - I'm not getting as far as "make" yet. At configure, it fails:
> Unable to locate External PROJ.4 includes.
> This, even if I use:
> --with-proj=/Library/Frameworks/PROJ.framework/Versions/4/Headers/proj_api.h
> (I know that PROJ.4 is installed, I'm using 6.4.0-RC4 with no worries!)
> Richard
> On 14/09/10 9:06 AM, William Kyngesburye wrote:
>> If you mean, install 6.4.0 without overwriting 6.4 RCs:
>> After you "make", don't "make install". Instead "make bindist". After it creates the Mac installer package, it leaves a full copy in macosx/dist (the staging area for creating the installer package), which you can move to whereever you like (or rename it).
>> If you mean, install GRASS 6.4.x without overwriting 6.3, then that's not a problem since the applications are named with the major.minor version.
>> Note that existing builds of Qgis.app will still use the older GRASS install, because of library linking, and setting the GRASS_GIS_BASE in Qgis to try to make it use the newer GRASS will only cause trouble. Qgis must be rebuilt to use the newer GRASS.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
