[GRASS-user] Two questions re 6.4 and OSX 10.4
    Richard Chirgwin
    rchirgwin at ozemail.com.au
    Sat Sep 18 02:37:14 EDT 2010
  William,
Make exits with an error in Nviz; /lib/nviz won't make. Here's the
/lib/nviz error:
>     (cd /usr/local/grass-6.4.0/dist./lib; ln -f -s
> libgrass_nviz.6.4.0.dylib
> /usr/local/grass-6.4.0/dist./lib/libgrass_nviz.dylib)
> ld: cycle in dylib re-exports with /usr/X11/lib/libGL.dylib
> collect2: ld returned 1 exit status
> make: *** [/usr/local/grass-6.4.0/dist./lib/libgrass_nviz.6.4.0.dylib]
> Error 1
Richard
On 17/09/10 11:47 PM, William Kyngesburye wrote:
> --with-proj --with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include --with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib --with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj
> On Sep 17, 2010, at 3:48 AM, Richard Chirgwin wrote:
>> William - I'm not getting as far as "make" yet. At configure, it fails:
>> Unable to locate External PROJ.4 includes.
>> This, even if I use:
>> --with-proj=/Library/Frameworks/PROJ.framework/Versions/4/Headers/proj_api.h
>> (I know that PROJ.4 is installed, I'm using 6.4.0-RC4 with no worries!)
>> Richard
>> On 14/09/10 9:06 AM, William Kyngesburye wrote:
>>> If you mean, install 6.4.0 without overwriting 6.4 RCs:
>>> After you "make", don't "make install".  Instead "make bindist".  After it creates the Mac installer package, it leaves a full copy in macosx/dist (the staging area for creating the installer package), which you can move to whereever you like (or rename it).
>>> If you mean, install GRASS 6.4.x without overwriting 6.3, then that's not a problem since the applications are named with the major.minor version.
>>> Note that existing builds of Qgis.app will still use the older GRASS install, because of library linking, and setting the GRASS_GIS_BASE in Qgis to try to make it use the newer GRASS will only cause trouble.  Qgis must be rebuilt to use the newer GRASS.
> William Kyngesburye<kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Time is an illusion - lunchtime doubly so."
> - Ford Prefect
