[GRASS-user] Re: self compile grass- msys
Venkatesh Raghavan
raghavan at media.osaka-cu.ac.jp
Fri Sep 17 10:07:44 EDT 2010
Hi Thy-san,
I wonder if you know there is a precompiled
Windows binary for GRASS-6.5 and GRASS-7 at
http://josef.fsv.cvut.cz/wingrass/grass65/
http://josef.fsv.cvut.cz/wingrass/grass70/
Best
Venka
On 2010/09/17 16:52, Pham Thy wrote:
> Hi Helmut,
> Thank you. Msys worked. But when I compiled it seams there are mistakes
> showing in the package.log in the below:
> Fri Sep 17 14:02:05 2010: STARTING configure
> checking host system type... i686-pc-mingw32
> checking for gcc... gcc
> checking whether the C compiler (gcc ) works... yes
> checking whether the C compiler (gcc ) is a cross-compiler... no
> checking whether we are using GNU C... yes
> checking whether gcc accepts -g... yes
> checking for Cygwin environment... no
> checking for mingw32 environment... yes
> checking for executable suffix... .exe
> checking for full floating-point support... yes
> checking for pwd... /c/mingw/bin/pwd
> checking for source directory... /osgeo4w/usr/src/grass64
> checking for build directory... /osgeo4w/usr/src/grass64
> checking for MacOSX App... no
> checking for MacOSX architectures... no
> checking for MacOSX SDK... no
> checking how to build libraries... shared
> checking for ranlib... ranlib
> checking how to run the C preprocessor... gcc -E
> checking if 64bit support is requested... no
> checking if 64bit Sparc VIS support is requested... no
> checking system version (for dynamic loading)...
> MINGW32_NT-5.2-1.0.11(0.46/3/2)
> checking for dlopen in -ldl... no
> checking for ar... ar
> checking for additional include dirs... /c/OSGeo4W/apps/gdal-16/include
> /c/OSGeo4W/include
> checking for additional library dirs... /c/OSGeo4W/apps/gdal-16/lib
> /c/OSGeo4W/lib
> checking for a BSD compatible install... /c/mingw/bin/install -c
> checking for flex... flex
> checking for yywrap in -lfl... no
> checking for bison... bison -y
> checking for env... env
> checking for perl... no
> checking for ANSI C header files... no
> checking for limits.h... yes
> checking for termio.h... no
> checking for termios.h... no
> checking for unistd.h... yes
> checking for values.h... yes
> checking for f2c.h... no
> checking for g2c.h... no
> checking for sys/ioctl.h... no
> checking for sys/mtio.h... no
> checking for sys/resource.h... no
> checking for sys/time.h... yes
> checking for sys/timeb.h... yes
> checking for sys/types.h... yes
> checking for sys/utsname.h... no
> checking for libintl.h... yes
> checking for iconv.h... yes
> checking for langinfo.h... no
> checking whether time.h and sys/time.h may both be included... yes
> checking for off_t... yes
> checking for uid_t in sys/types.h... no
> checking return type of signal handlers... void
> checking for ftime... no
> checking for gethostname... no
> checking for gettimeofday... no
> checking for lseek... no
> checking for nice... no
> checking for time... no
> checking for uname... no
> checking for seteuid... no
> checking for setpriority... no
> checking for setreuid... no
> checking for setruid... no
> checking for drand48... no
> checking for putenv... no
> checking for setenv... no
> checking for nanosleep... no
> checking whether setpgrp takes no argument... yes
> checking for long long int... yes
> checking for W11... no
> checking for X... disabled
> checking whether to use Curses... yes
> checking for curses.h... yes
> checking curses.h WINDOW structure component... _maxy
> checking for initscr in -lncurses... no
> checking for initscr in -lcurses... no
> Therefore there is no "bin" folder in /osgeo4w/apps/grass/ when run grass
> Please show me my mistake.
> Thank in advance
> Thy
>> in the OSGeo4W installer-setup choose "advanced installation". in the
>> command-line utilities-section you have to choose explicitly "msys - a
>> Minimal system" to install msys inside Osgeo4W-stack and a
>> desktop-icon msys.
>> if you have installed osgeo4w under c:\OSGeo4W, then the msys-folder
>> should live in C:\OSGeo4W\apps\msys.
>> best regards
>> Helmut
>> ___________________________________________________________
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
