[GRASS-user] self compile grass- msys
Helmut Kudrnovsky
hellik at web.de
Sat Sep 18 08:11:28 EDT 2010
>Yes, I installed it in c/osgeo4w
>But there is not any "error.log" file in /osgeo4w/usr/src/grass64/
>I tried to run compile again and it appeared the error in msys:
>checking ...
>configure: error: *** Unable to locate curses library.]
>Thy
in http://trac.osgeo.org/grass/wiki/CompileOnWindows
following dependecies to install via the osgeo4w-installer-setup are listed:
6. Also select:
* Commandline_Utilities:
* avce00
* gpsbabel
* Libs:
* fftw-devel
* freetype-devel
* freetype-devel-mingw
* gsl-libs
* gsl-devel
* libpng-devel
* libpng-devel-mingw
* libtiff-devel
* libxdr
* mingw-libs (contains mingw-style libraries for VC build binaries and depends on gdal, libpq, libjpeg-devel, sqlite3, libtiff, zlib, proj)
* pdcurses-devel <=
* tcltk-devel
* zlib-devel
please check if you have installed all these dependecies, especially pdcurses-devel (see above)
best regards
Helmut
___________________________________________________________
GRATIS: Spider-Man 1-3 sowie 300 weitere Videos!
Jetzt kostenlose Movie-FLAT freischalten! http://movieflat.web.de
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20100918/06d3102f/smime.bin
