[GRASS-user] self compile grass- msys
Pham Thi Mai Thy ptmthy at media.osaka-cu.ac.jp
Tue Sep 21 01:54:29 EDT 2010
Hi
>> Yes, I installed it in c/osgeo4w
>> But there is not any "error.log" file in /osgeo4w/usr/src/grass64/
>> I tried to run compile again and it appeared the error in msys:
>> checking ...
>> configure: error: *** Unable to locate curses library.]
>> Thy
> in http://trac.osgeo.org/grass/wiki/CompileOnWindows
> following dependecies to install via the osgeo4w-installer-setup are listed:
> 6. Also select:
> * Commandline_Utilities:
> * avce00
> * gpsbabel
> * Libs:
> * fftw-devel
> * freetype-devel
> * freetype-devel-mingw
> * gsl-libs
> * gsl-devel
> * libpng-devel
> * libpng-devel-mingw
> * libtiff-devel
> * libxdr
> * mingw-libs (contains mingw-style libraries for VC build binaries and depends on gdal, libpq, libjpeg-devel, sqlite3, libtiff, zlib, proj)
> * pdcurses-devel       <=
> * tcltk-devel
> * zlib-devel
> please check if you have installed all these dependecies, especially pdcurses-devel (see above)
> best regards
> Helmut
Yes, I selected all of them. It was ran in Window 64bit. What should I do?
Thy
