[GRASS-user] unsuccesful installing r.univar2.zonal with g.extension
Vishal Mehta
vishalm1975 at gmail.com
Tue Sep 21 19:24:48 EDT 2010
I just tried installing r.univar2.zonal using g.extension. i am using
Grass6.5svn
I got an error at the end "Module did not install properly"
As a test I also tried (successfully)
GRASS 6.5.svn (cru):~/himalaya > g.extension extension=v.rast.stats2
Here is what happened with r.univar2.zonal: any ideas?
GRASS 6.5.svn (cru):~/himalaya > g.extension extension=r.univar2.zonal
Fetching <r.univar2.zonal> from GRASS-Addons SVN (be patient)...
A r.univar2.zonal/stats.c
A r.univar2.zonal/sort.c
A r.univar2.zonal/globals.h
A r.univar2.zonal/r.univar.zonal.html
A r.univar2.zonal/r.univar_main.c
A r.univar2.zonal/r3.univar.zonal.html
A r.univar2.zonal/r3.univar_main.c
A r.univar2.zonal/Makefile
U r.univar2.zonal
Checked out revision 43600.
Compiling <r.univar2.zonal>...
test -d OBJ.i686-pc-linux-gnu || mkdir -p OBJ.i686-pc-linux-gnu
gcc -I/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/include -g
-O2 -DPACKAGE=\""grassmods"\"
-I/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/include -o
OBJ.i686-pc-linux-gnu/r.univar_main.o -c r.univar_main.c
OBJ.i686-pc-linux-gnu/sort.o -c sort.c
OBJ.i686-pc-linux-gnu/stats.o -c stats.c
gcc -L/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/lib
-Wl,--export-dynamic
-Wl,-rpath-link,/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/lib
-L/usr/local/pgsql/lib/ -o
/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/bin/r.univar.zonal
OBJ.i686-pc-linux-gnu/r.univar_main.o OBJ.i686-pc-linux-gnu/sort.o
OBJ.i686-pc-linux-gnu/stats.o -lgrass_g3d -lgrass_gis -lgrass_datetime
-lz -lgrass_gis -lgrass_datetime -lz -lz -lm
OBJ.i686-pc-linux-gnu/r3.univar_main.o -c r3.univar_main.c
/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/bin/r3.univar.zonal
OBJ.i686-pc-linux-gnu/r3.univar_main.o OBJ.i686-pc-linux-gnu/sort.o
-lz -lgrass_gis -lgrass_dModule did not install properlyatetime -lz
-lz -lm
make htmlmulti
make[1]: Entering directory
`/home/vishal/grassdata/cru/rad/.tmp/SEI-Davis/8982.0/r.univar2.zonal'
for prog in r.univar.zonal r3.univar.zonal ; do make htmlcmd PGM=$prog ;
done
make[2]: Entering directory
make
/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/docs/html/r.univar.zonal.html
HTMLSRC=/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/bin/r.univar.zonal
make[3]: Entering directory
if [ "/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/bin/r.univar.zonal"
!= "" ] ; then
GISRC=/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/demolocation/.grassrc65
GISBASE=/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu
PATH="/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/bin:$PATH"
LD_LIBRARY_PATH="/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/bin:/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/lib:/usr/local/grass-6.5.svn/lib"
LC_ALL=C
--html-description < /dev/null | grep -v '</body>\|</html>' >
r.univar.zonal.tmp.html ; true ; fi
/usr/local/grass-6.5.svn/tools/mkhtml.sh r.univar.zonal ; mkdir -p
/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/docs/html ;
/usr/bin/install -c -m 644 r.univar.zonal.tmp.html
; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ;
if [ $? -ne 0 ] ; then /usr/bin/install -c -m 644 $file
/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/docs/html ; fi done 2>
/dev/null ; true
make[3]: Leaving directory
make[2]: Leaving directory
make
/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/docs/html/r3.univar.zonal.html
HTMLSRC=/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/bin/r3.univar.zonal
if [
"/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/bin/r3.univar.zonal" !=
"" ] ; then
LC_ALL=C
r3.univar.zonal.tmp.html ; true ; fi
/usr/local/grass-6.5.svn/tools/mkhtml.sh r3.univar.zonal ; mkdir -p
/usr/bin/install -c -m 644 r3.univar.zonal.tmp.html
/dev/null ; true
make[1]: Leaving directory
Installing r.univar2.zonal...
if [ "" != "" ] ; then \
for dir in ; do \
make -C $dir install ; \
done ; \
fi
ERROR: Module did not install properly
Thanks,
Vishal
Vishal K. Mehta, PhD
Scientist
Stockholm Environment Institute - US
133 D St Suite F
Davis CA 95616
www.sei-us.org
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100921/8c77f0bd/attachment.html
