[GRASS-user] Connecting GRASS to a MySQL database?
PixelPusher pixelpusher at cox.net
Wed Sep 22 16:51:08 EDT 2010
Sorry for the n00bish question, but I'm confused by the GRASS on-line
docs.
I have a MySQL database running on my local computer. Let's say that the
MySQL user name is TRD and he has access to a database called TRD where
I want to store my StateBoundaries table.
I can start the  GRASS (6.4.0) Python interface and select
"Database->Manage Databases->Connect" from the pulldown menu. I am then
faced with the choice of driver, where I select "mysql". But, then it
needs the Database name. This is where I get lost. The string in the
text field says, "$GISDBASE/$LOCATION_NAME/$MAPSET/TRD". I'm not sure
where GRASS is getting the values that substitute for those things that
look like script variables. I guess the "$LOCATION_NAME" and "$MAPSET"
come from the location and mapset that I selected when GRASS started.
But, where is "$GISDBASE" set?
I also step through the log in process by setting the appropriate user
name and password. I know that I can use this combination to access the
MySQL database through its command line interface.
The next thing I do is try to test the connection. However, this results
in lots of errors like, "Cannot connect to MySQL, Access denied for
user" and "ERROR: Unable to open database
<$GISDBASE/$LOCATION_NAME/$MAPSET/TRD>". It looks like GRASS is not
using the right username and password and not doing the variable
substitution that I was expecting.
Can anoyone give me some hints on how to get this thing started?
Thanks!
Thom
    Man will occasionally stumble over the truth, but most of the time
    he will pick himself up and continue.              -- Winston
Churchill
