[GRASS-user] Projection information
stephen sefick
ssefick at gmail.com
Thu Sep 23 07:53:15 EDT 2010
Hamish,
Thank you very much. I set the zone to 17 which is the right utm zone
for "ftbr". All of the input data has been in or transformed to the
right projection I guess I just didn't set this up correctly when I
created the projection location. Thanks so much for all of your help.
kindest regards,
Stephen Sefick
On Wed, Sep 22, 2010 at 11:09 PM, Hamish <hamish_b at yahoo.com> wrote:
> stephen sefick wrote:
>> These are three different projection
>> locations that I have set up over
>> the past year with ever changing GRASSes. tcl/tk
>> interface up to the
>> new GRASS6.4.1svn. I have consistently kept
>> everything in the correct
>> projections for input data.
>> ftbn: utm nad83 grs80 zone 17
>> srs: utm nad83 grs80 zone 17
>> should I be worried that the ProjInfo files for the three
>> below differ slightly? Can I safely make them all look the
>> same? Does this matter? Thanks in advance for all of the help.
>> ftbr:
>> name: Universal Transverse Mercator
>> datum: nad83
>> towgs84: 0.000,0.000,0.000
>> proj: utm
>> ellps: grs80
>> a: 6378137.0000000000
>> es: 0.0066943800
>> f: 298.2572221010
> a, es, and f are just grs80 expanded, try `proj -le` from the command line.
> +towgs84=0,0,0 pretty much means "don't do anything to get to wgs84"
> I see that proj=utm but the zone= is missing. If so, the projection
> definition is incomplete.
>> srs:
>> proj: utm
>> datum: nad83
>> ellps: grs80
>> zone: 17
>> no_defs: defined
> equivalent, see http://trac.osgeo.org/proj/wiki/GenParms for details.
>> ftbn:
>> datum: nad83
>> proj: utm
>> ellps: grs80
>> es: 0.0066943800
>> f: 298.2572221010
>> zone: 16
> note the above says zone 16, not 17. otherwise equivalent.
> Hamish
Stephen Sefick
____________________________________
| Auburn University |
| Department of Biological Sciences |
| 331 Funchess Hall |
| Auburn, Alabama |
| 36849 |
|___________________________________|
| sas0025 at auburn.edu |
| http://www.auburn.edu/~sas0025 |
Let's not spend our time and resources thinking about things that are
so little or so large that all they really do for us is puff us up and
make us feel like gods. We are mammals, and have not exhausted the
annoying little problems of being mammals.
-K. Mullis
"A big computer, a complex algorithm and a long time does not equal science."
-Robert Gentleman
