[GRASS-user] First time trying to install add on g.extension
	(r.stream.order)
    David Birkigt
    dbbirkigt at gmail.com
    Fri Sep 24 18:15:22 EDT 2010
I am fairly new to GRASS and have what many of you would consider a trivial
or newb problem. Regardless any help would be appreciated.
 Using GRASS 6.4.0 on windows vista I type "g.extension
extension=r.stream.order" in the command line at the bottom of the layer
manager window. The following error is returned:
 "Error:  svn client required. Please install Subversion first."
I have looked through many posts and help files to no avail, if anyone can
tell me what additional steps/programs/plugins are required to install
addons I would really appreciate the help.
Thanks
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100924/635c0a0e/attachment.html
