[GRASS-user] Connecting GRASS to a MySQL database ?
Thom DeCarlo
pixelpusher at cox.net
Sat Sep 25 02:23:08 EDT 2010
Richard,
Yeah... Merge might not be the right word. I'm importing a lot of files
downloaded from the USGS site, for example, state boundaries. There are 6
separate files, but I want them all to go into the same database table/map
layer. The import vector function always wants to put each import into its
own table/layer.
Thom
Sent via DROID on Verizon Wireless
-----Original message-----
From: Richard Chirgwin <rchirgwin at ozemail.com.au>
To: Thom DeCarlo <pixelpusher at cox.net>
Cc: grass-user at lists.osgeo.org
Sent: 2010 Sep, Fri, 24 21:46:26 GMT+00:00
Subject: Re: [GRASS-user] Connecting GRASS to a MySQL database?
It depends on what you mean by "merge".
v.patch is the "official" tool to merge two vectors, but you could use
v.overlay (option=or).
Richard
On 24/09/10 10:56 PM, Thom DeCarlo wrote:
> Richard,
> Thanks! That was exactly the information I needed.
> Now to figure out how to merge layers...
> Thom
> /Sent via DROID on Verizon Wireless/
> *From: *Richard Chirgwin <rchirgwin at ozemail.com.au>*
> To: *grass-user at lists.osgeo.org*
> Sent: *2010 Sep, Thu, 23 07:20:51 GMT+00:00*
> Subject: *Re: [GRASS-user] Connecting GRASS to a MySQL database?
> On 23/09/10 5:13 PM, grass-user-request at lists.osgeo.org wrote:
> > Message: 3
> > Date: Wed, 22 Sep 2010 16:51:08 -0400 (EDT)
> > From: PixelPusher
> > Subject: [GRASS-user] Connecting GRASS to a MySQL database?
> > To:grass-user at lists.osgeo.org
> > Message-ID:
> > Content-Type: text/plain; charset=UTF-8; format=flowed; delsp=no
> > Sorry for the n00bish question, but I'm confused by the GRASS
> on-line
> > docs.
> > I have a MySQL database running on my local computer. Let's say
> that the
> > MySQL user name is TRD and he has access to a database called
> TRD where
> > I want to store my StateBoundaries table.
> > I can start the GRASS (6.4.0) Python interface and select
> > "Database->Manage Databases->Connect" from the pulldown menu. I
> am then
> > faced with the choice of driver, where I select "mysql". But,
> then it
> > needs the Database name. This is where I get lost. The string in the
> > text field says, "$GISDBASE/$LOCATION_NAME/$MAPSET/TRD". I'm not
> sure
> > where GRASS is getting the values that substitute for those
> things that
> > look like script variables. I guess the "$LOCATION_NAME" and
> "$MAPSET"
> > come from the location and mapset that I selected when GRASS
> started.
> > But, where is "$GISDBASE" set?
> > I also step through the log in process by setting the
> appropriate user
> > name and password. I know that I can use this combination to
> access the
> > MySQL database through its command line interface.
> > The next thing I do is try to test the connection. However, this
> results
> > in lots of errors like, "Cannot connect to MySQL, Access denied for
> > user" and "ERROR: Unable to open database
> > <$GISDBASE/$LOCATION_NAME/$MAPSET/TRD>". It looks like GRASS is not
> > using the right username and password and not doing the variable
> > substitution that I was expecting.
> > Can anoyone give me some hints on how to get this thing started?
> > Thanks!
> > Thom
> Thom,
> Having taught a few people how to use Grass-GIS, I can say that
> database parameters confuse a great many of them!
> The parameters you see are for the default dbf driver (Grass-GIS
> uses this driver as the default for any new mapset). For MySQL,
> you provide the database location, and also login.
> So where you see the $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/ string,
> you want:
> database=host=,dbname=TRD
> But you'll also have to login. Eg (command line):
> db.login user=TRD password="somepassword"
> (the inverted commas are needed at the command line but not using
> the GUI)
> Notes:
> 1. From now on, every map you make in this particular mapset will
> use the MySQL database as its default connection. Don't try to mix
> different database drivers within a mapset - you'll get a headache!
> 2. Database parameters are stored only within the mapset you're
> using. If you want to connect a different mapset to MySQL, you
> have to set its connection.
> Richard Chirgwin
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100925/a8ad12e7/attachment.html
