[GRASS-user] Region and not-processed data
Kim Besson
kimbesson1981 at gmail.com
Mon Sep 27 09:58:32 EDT 2010
Hi stephen and rest of GRASS users
That was not my quiestion. My question is: if a have a an uimage inside a
regions, will it process and run for all the region or only for where I have
the image(it's not importing only image-processing). ?
Thanks
Kim
2010/9/27 stephen sefick <ssefick at gmail.com>
> I get a little confused with the region raster processing stuff also.
> But, this is what I do, and it seems to work. Anything that is
> brought in from the outside (r.in.*) will import the entire map.
> Anything that is done withing GRASS will respect the region. So, just
> make sure to set the region before each calculation and you should be
> OK.
> On Mon, Sep 27, 2010 at 8:52 AM, Kim Besson <kimbesson1981 at gmail.com>
> wrote:
> > Greetings
> > I have a very "dumb" question regarding region definition/processing:
> > - I have defined a an area (example; 30N 20S -10W -5W). I have a raster
> > image with (30N 15N -7W -5) I mean, it only cover a part of the region.
> If I
> > run GRASS image-processing algorithms and processors does it run in all
> > image or only where I have a raster image?
> > Thanks and sorry for tyhis such a dumb question
> > Kim
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
> Stephen Sefick
> | Auburn University |
> | Department of Biological Sciences |
> | 331 Funchess Hall |
> | Auburn, Alabama |
> | 36849 |
> |___________________________________|
> | sas0025 at auburn.edu |
> | http://www.auburn.edu/~sas0025 |
> Let's not spend our time and resources thinking about things that are
> so little or so large that all they really do for us is puff us up and
> make us feel like gods. We are mammals, and have not exhausted the
> annoying little problems of being mammals.
> -K. Mullis
> "A big computer, a complex algorithm and a long time does not equal
> science."
> -Robert Gentleman
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100927/6712d7f4/attachment.html
