[GRASS-user] Region and not-processed data
stephen sefick
ssefick at gmail.com
Mon Sep 27 10:01:37 EDT 2010
Where you don't have the image, if I understand you correctly, would
be NULL values? In that case you will have to default to someone more
experienced, but I suspect that it is run on the entire map, but NULL
means no data so no process. Just a wag.
hth
Stephen
On Mon, Sep 27, 2010 at 8:58 AM, Kim Besson <kimbesson1981 at gmail.com> wrote:
> Hi stephen and rest of GRASS users
> That was not my quiestion. My question is: if a have a an uimage inside a
> regions, will it process and run for all the region or only for where I have
> the image(it's not importing only image-processing). ?
> Thanks
> Kim
> 2010/9/27 stephen sefick <ssefick at gmail.com>
>> I get a little confused with the region raster processing stuff also.
>> But, this is what I do, and it seems to work. Anything that is
>> brought in from the outside (r.in.*) will import the entire map.
>> Anything that is done withing GRASS will respect the region. So, just
>> make sure to set the region before each calculation and you should be
>> OK.
>> On Mon, Sep 27, 2010 at 8:52 AM, Kim Besson <kimbesson1981 at gmail.com>
>> wrote:
>> > Greetings
>> > I have a very "dumb" question regarding region definition/processing:
>> > - I have defined a an area (example; 30N 20S -10W -5W). I have a raster
>> > image with (30N 15N -7W -5) I mean, it only cover a part of the region.
>> > If I
>> > run GRASS image-processing algorithms and processors does it run in all
>> > image or only where I have a raster image?
>> > Thanks and sorry for tyhis such a dumb question
>> > Kim
>> > _______________________________________________
>> > grass-user mailing list
>> > grass-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/grass-user
>> Stephen Sefick
>> | Auburn University |
>> | Department of Biological Sciences |
>> | 331 Funchess Hall |
>> | Auburn, Alabama |
>> | 36849 |
>> |___________________________________|
>> | sas0025 at auburn.edu |
>> | http://www.auburn.edu/~sas0025 |
>> Let's not spend our time and resources thinking about things that are
>> so little or so large that all they really do for us is puff us up and
>> make us feel like gods. We are mammals, and have not exhausted the
>> annoying little problems of being mammals.
>> -K. Mullis
>> "A big computer, a complex algorithm and a long time does not equal
>> science."
>> -Robert Gentleman
Stephen Sefick
| Auburn University |
| 331 Funchess Hall |
| Auburn, Alabama |
| 36849 |
-K. Mullis
"A big computer, a complex algorithm and a long time does not equal science."
-Robert Gentleman
