[GRASS-user] Region and not-processed data
Kim Besson
kimbesson1981 at gmail.com
Tue Sep 28 09:17:06 EDT 2010
Hi
Ok about this I just need to have an idea (or a link that can explain me
this):
1- When I import a raster map (r.in.gdal) will it import all the raster or
only the portion that fits in the current defined region?
2- If I define as a region a wider area than the image, will it process
where the image is not available?
Thanks
Kim
2010/9/27 stephen sefick <ssefick at gmail.com>
> Where you don't have the image, if I understand you correctly, would
> be NULL values? In that case you will have to default to someone more
> experienced, but I suspect that it is run on the entire map, but NULL
> means no data so no process. Just a wag.
> hth
> Stephen
> On Mon, Sep 27, 2010 at 8:58 AM, Kim Besson <kimbesson1981 at gmail.com>
> wrote:
> > Hi stephen and rest of GRASS users
> > That was not my quiestion. My question is: if a have a an uimage inside a
> > regions, will it process and run for all the region or only for where I
> have
> > the image(it's not importing only image-processing). ?
> > Thanks
> > Kim
> >> I get a little confused with the region raster processing stuff also.
> >> But, this is what I do, and it seems to work. Anything that is
> >> brought in from the outside (r.in.*) will import the entire map.
> >> Anything that is done withing GRASS will respect the region. So, just
> >> make sure to set the region before each calculation and you should be
> >> OK.
> >> On Mon, Sep 27, 2010 at 8:52 AM, Kim Besson <kimbesson1981 at gmail.com>
> >> wrote:
> >> > Greetings
> >> > I have a very "dumb" question regarding region definition/processing:
> >> > - I have defined a an area (example; 30N 20S -10W -5W). I have a
> raster
> >> > image with (30N 15N -7W -5) I mean, it only cover a part of the
> region.
> >> > If I
> >> > run GRASS image-processing algorithms and processors does it run in
> all
> >> > image or only where I have a raster image?
> >> > Thanks and sorry for tyhis such a dumb question
> >> > Kim
> >> > _______________________________________________
> >> > grass-user mailing list
> >> > grass-user at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/grass-user
> >> Stephen Sefick
> >> | Auburn University |
> >> | Department of Biological Sciences |
> >> | 331 Funchess Hall |
> >> | Auburn, Alabama |
> >> | 36849 |
> >> |___________________________________|
> >> | sas0025 at auburn.edu |
> >> | http://www.auburn.edu/~sas0025 |
> >> Let's not spend our time and resources thinking about things that are
> >> so little or so large that all they really do for us is puff us up and
> >> make us feel like gods. We are mammals, and have not exhausted the
> >> annoying little problems of being mammals.
> >> -K. Mullis
> >> "A big computer, a complex algorithm and a long time does not equal
> >> science."
> >> -Robert Gentleman
> Stephen Sefick
> | Auburn University |
> | 331 Funchess Hall |
> | Auburn, Alabama |
> | 36849 |
> -K. Mullis
> science."
> -Robert Gentleman
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100928/dea91756/attachment-0001.html
