[GRASS-user] Region and not-processed data
stephen sefick
ssefick at gmail.com
Tue Sep 28 09:33:15 EDT 2010
This thread in the archives may answer your questions.
http://osgeo-org.1803224.n2.nabble.com/Import-question-td5551110.html#a5558429
HTH,
Stephen Sefick
On Tue, Sep 28, 2010 at 8:17 AM, Kim Besson <kimbesson1981 at gmail.com> wrote:
> Hi
> Ok about this I just need to have an idea (or a link that can explain me
> this):
> 1- When I import a raster map (r.in.gdal) will it import all the raster or
> only the portion that fits in the current defined region?
> 2- If I define as a region a wider area than the image, will it process
> where the image is not available?
> Thanks
> Kim
> 2010/9/27 stephen sefick <ssefick at gmail.com>
>> Where you don't have the image, if I understand you correctly, would
>> be NULL values? In that case you will have to default to someone more
>> experienced, but I suspect that it is run on the entire map, but NULL
>> means no data so no process. Just a wag.
>> hth
>> Stephen
>> On Mon, Sep 27, 2010 at 8:58 AM, Kim Besson <kimbesson1981 at gmail.com>
>> wrote:
>> > Hi stephen and rest of GRASS users
>> > That was not my quiestion. My question is: if a have a an uimage inside
>> > a
>> > regions, will it process and run for all the region or only for where I
>> > have
>> > the image(it's not importing only image-processing). ?
>> > Thanks
>> > Kim
>> >> I get a little confused with the region raster processing stuff also.
>> >> But, this is what I do, and it seems to work. Anything that is
>> >> brought in from the outside (r.in.*) will import the entire map.
>> >> Anything that is done withing GRASS will respect the region. So, just
>> >> make sure to set the region before each calculation and you should be
>> >> OK.
>> >> On Mon, Sep 27, 2010 at 8:52 AM, Kim Besson <kimbesson1981 at gmail.com>
>> >> wrote:
>> >> > Greetings
>> >> > I have a very "dumb" question regarding region definition/processing:
>> >> > - I have defined a an area (example; 30N 20S -10W -5W). I have a
>> >> > raster
>> >> > image with (30N 15N -7W -5) I mean, it only cover a part of the
>> >> > region.
>> >> > If I
>> >> > run GRASS image-processing algorithms and processors does it run in
>> >> > all
>> >> > image or only where I have a raster image?
>> >> > Thanks and sorry for tyhis such a dumb question
>> >> > Kim
>> >> > _______________________________________________
>> >> > grass-user mailing list
>> >> > grass-user at lists.osgeo.org
>> >> > http://lists.osgeo.org/mailman/listinfo/grass-user
>> >> Stephen Sefick
>> >> | Auburn University |
>> >> | Department of Biological Sciences |
>> >> | 331 Funchess Hall |
>> >> | Auburn, Alabama |
>> >> | 36849 |
>> >> |___________________________________|
>> >> | sas0025 at auburn.edu |
>> >> | http://www.auburn.edu/~sas0025 |
>> >> Let's not spend our time and resources thinking about things that are
>> >> so little or so large that all they really do for us is puff us up and
>> >> make us feel like gods. We are mammals, and have not exhausted the
>> >> annoying little problems of being mammals.
>> >> -K. Mullis
>> >> "A big computer, a complex algorithm and a long time does not equal
>> >> science."
>> >> -Robert Gentleman
>> Stephen Sefick
>> | Auburn University |
>> | 331 Funchess Hall |
>> | Auburn, Alabama |
>> | 36849 |
>> -K. Mullis
>> science."
>> -Robert Gentleman
Stephen Sefick
| Auburn University |
| 331 Funchess Hall |
| Auburn, Alabama |
| 36849 |
-K. Mullis
"A big computer, a complex algorithm and a long time does not equal science."
-Robert Gentleman
