[GRASS-user] how to v.label d.labels usage - labels do not appear
lara
Laleluia at gmail.com
Tue Sep 28 06:02:55 EDT 2010
Dear all
I am quite new to GRASS, only use it few times.
I need to label my points, so i tried to use v.label
i have this file which i imported with :
v.in.ascii --o in=/stations_LU_AB out=stations_LU_ab
705131.45|5513243.33|LU0104A
738198.49|5513485.53|LU0105A
715628.70|5486561.69|LU0001A
739861.59|5489430.06|LU0099A
715474.80|5488410.95|LU0102A
726771.85|5500003.64|LU0013A
726722.32|5499259.57|LU0101A
725889.30|5499966.84|LU0100A
710345.43|5504908.79|LU0008A
727890.58|5537167.57|LU0103A
725969.76|5499970.19|LU0012A
717207.29|5487366.69|LU0107A
728209.78|5537181.14|LU0018A
725777.59|5505529.71|LU0106A
and it works fine... then i used v.label
v.label labels=stat_labels map=stations_LU_ab column=cat type=point,centroid
layer=1 xoffset=0 yoffset=0 reference=center font=standard size=100
color=black rotation=0 width=1 hcolor=none hwidth=0 background=none
border=none opaque=yes
... there were no complains:
"Labeled 14 lines."
and finally :
d.vect stations_LU_ab
d.labels stat_labels
and it nothing appears ... :(
Could you give me some lights in what I am doing wrong?
I thank you in advance
Lara A. REis
View this message in context: http://osgeo-org.1803224.n2.nabble.com/how-to-v-label-d-labels-usage-labels-do-not-appear-tp5578731p5578731.html
Sent from the Grass - Users mailing list archive at Nabble.com.
