[GRASS-user] how to v.label d.labels usage - labels do not appear
Micha Silver micha at arava.co.il
Tue Sep 28 06:49:13 EDT 2010
On 28/09/2010 12:02, lara wrote:
> Dear all
> I am quite new to GRASS, only use it few times.
> I need to label my points, so i tried to use v.label
> i have this file which i imported with :
>   v.in.ascii --o in=/stations_LU_AB out=stations_LU_ab
> 705131.45|5513243.33|LU0104A
> 738198.49|5513485.53|LU0105A
> 715628.70|5486561.69|LU0001A
> 739861.59|5489430.06|LU0099A
> 715474.80|5488410.95|LU0102A
> 726771.85|5500003.64|LU0013A
> 726722.32|5499259.57|LU0101A
> 725889.30|5499966.84|LU0100A
> 710345.43|5504908.79|LU0008A
> 727890.58|5537167.57|LU0103A
> 725969.76|5499970.19|LU0012A
> 717207.29|5487366.69|LU0107A
> 728209.78|5537181.14|LU0018A
> 725777.59|5505529.71|LU0106A
> and it works fine... then i used v.label
> v.label labels=stat_labels map=stations_LU_ab column=cat type=point,centroid
> layer=1 xoffset=0 yoffset=0 reference=center font=standard size=100
> color=black rotation=0 width=1 hcolor=none hwidth=0 background=none
> border=none opaque=yes
> ... there were no complains:
> "Labeled 14 lines."
> and finally :
> d.vect stations_LU_ab
> d.labels stat_labels
> and it nothing appears ... :(
Maybe you're not at the right region. Try first:
g.region vect=stations_LU_ab
> Could you give me some lights in what I am doing wrong?
> I thank you in advance
> Lara A. REis
Micha Silver
http://www.surfaces.co.il/
Arava Development Co.  +972-52-3665918
