[GRASS-user] I need some help to import a GIS file to GRASS64
Ivan Henriquez Rivera
ivan.henriquez at upr.edu
Thu Sep 30 05:13:54 EDT 2010
Hello!
My name is Ivan.
I have been trying to import a GIS raster flie to GRASS64.
I do the next proucedure in Ubuntu 10.04:
-I run grass64
-I define a new location using the EPSG code: 32161 (based in the
information at the end of this email)
-When Grass asks me: Select datum transformation parameters,
I choose the second one: (Used in whole nad83 region. towgs84 = 0.000,
0.000, 0.000)
-Then I enter in the PERMANENT folder.
And then I do this:
r.in.gdal input=/home/ivan/grassdata/prgap_landcover.img output=puertoRico
Projection of input dataset and current location appear to match
r.in.gdal complete. Raster map <puertoRico> created.
d.rast map=puertoRico at PERMANENT -o
PNG: GRASS_TRUECOLOR status: TRUE
PNG: collecting to file:
/home/ivan/grassdata/pr/PERMANENT/.tmp/ivan-laptop/6771.0.ppm,
GRASS_WIDTH=642, GRASS_HEIGHT=482
g.pnmcomp in=6771.2.ppm mask=6771.2.pgm opacity=1.0 background=255:255:255
width=642 height=482 output=6771.1.ppm
GRASS_WIDTH=482, GRASS_HEIGHT=482
width=482 height=482 output=6771.1.ppm
g.region n=18.529654 s=17.874067 e=-65.218506 w=-67.957335 rows=4793
cols=19279 nsres=15 ewres=15 tbres=1
/home/ivan/grassdata/pr/PERMANENT/.tmp/ivan-laptop/6771.3.ppm,
GRASS_WIDTH=642, GRASS_HEIGHT=154
g.pnmcomp in=6771.5.ppm mask=6771.5.pgm opacity=1.0 background=255:255:255
width=642 height=154 output=6771.4.ppm
The problem is that the Map Display is in blank.
If you want to try it, you can donwload the file from
ftp://ftp.gap.uidaho.edu/products/Puerto_Rico/GISdata/Landcover/1_Land_cover_grid/
the file is prgap_landcover.zip<ftp://ftp.gap.uidaho.edu/products/Puerto_Rico/GISdata/Landcover/1_Land_cover_grid/prgap_landcover.zip>,
and inside you will find the a .img file
Here I add more Information:
Spatial_Domain:
Bounding_Coordinates:
West_Bounding_Coordinate: -67.957335
East_Bounding_Coordinate: -65.218506
North_Bounding_Coordinate: 18.529654
South_Bounding_Coordinate: 17.874067
Spatial_Data_Organization_Information:
Direct_Spatial_Reference_Method: Raster
Raster_Object_Information:
Raster_Object_Type: Pixel
Row_Count: 4793
Column_Count: 19279
Vertical_Count: 1
Spatial_Reference_Information:
Horizontal_Coordinate_System_Definition:
Planar:
Map_Projection:
Map_Projection_Name: Lambert Conformal Conic
Lambert_Conformal_Conic:
Standard_Parallel: 18.033333
Standard_Parallel: 18.433333
Longitude_of_Central_Meridian: -66.433333
Latitude_of_Projection_Origin: 17.833333
False_Easting: 200000.000000
False_Northing: 200000.000000
Planar_Coordinate_Information:
Planar_Coordinate_Encoding_Method: row and column
Coordinate_Representation:
Abscissa_Resolution: 15
Ordinate_Resolution: 15
Planar_Distance_Units: meters
Geodetic_Model:
Horizontal_Datum_Name: North American Datum of 1983
Ellipsoid_Name: Geodetic Reference System 80
Semi-major_Axis: 6378137.000000
Denominator_of_Flattening_Ratio: 298.257222
Entity_and_Attribute_Information:
Detailed_Description:
Entity_Type:
Entity_Type_Label: Layer_1
Attribute:
Attribute_Label: ObjectID
Attribute_Definition: Internal feature number.
Attribute_Definition_Source: ESRI
Attribute_Domain_Values:
Unrepresentable_Domain: Sequential unique whole numbers that
are automatically generated.
Attribute:
Attribute_Label: Value
Attribute_Definition: A number assigned to each specific land
cover class or type.
Attribute:
Attribute_Label: Red
Attribute:
Attribute_Label: Green
Attribute:
Attribute_Label: Blue
Attribute:
Attribute_Label: Class_names
Attribute_Definition: Land cover types
Attribute:
Attribute_Label: Opacity
Attribute:
Attribute_Label: Count
Attribute_Definition: Number of pixels of each land cover type.
Standard_Order_Process:
Digital_Form:
Digital_Transfer_Information:
Format_Name: ERDAS
Format_Version_Date: November 03, 2006.
Format_Specification: This landcover was developed using ERDAS
IMAGINE 8.7.
Format_Information_Content: This raster dataset represent the
landcover for Puerto Rico and it's adyacent islands.
File_Decompression_Technique: no compression applied
Transfer_Size: 0.000
Thanks for your help!
Iván Henríquez
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100930/d8192e58/attachment-0001.html
