[GRASS-user] I need some help to import a GIS file to GRASS64
Benjamin Ducke benjamin.ducke at oxfordarch.co.uk
Thu Sep 30 05:28:10 EDT 2010
Are you sure you have the right extents?
Try
 g.region rast=puertoRico
then display again. Also, you could try:
 r.info puertoRico
to get the raster statistics and extent and check
if it makes sense.
Are you on Windows?
The output below shows that the map is being written
to a PNG output file. Did you check that file?
Cheers,
Ben
----- Original Message -----
> Hello!
> My name is Ivan.
> I have been trying to import a GIS raster flie to GRASS64.
> I do the next proucedure in Ubuntu 10.04:
> -I run grass64
> -I define a new location using the EPSG code: 32161 (based in the
> information at the end of this email)
> -When Grass asks me: Select datum transformation parameters,
> I choose the second one: (Used in whole nad83 region. towgs84 = 0.000,
> 0.000, 0.000)
> -Then I enter in the PERMANENT folder.
> And then I do this:
> r.in.gdal input=/home/ivan/grassdata/prgap_landcover.img
> output=puertoRico Projection of input dataset and current location
> appear to match
> r.in.gdal complete. Raster map <puertoRico> created.
> d.rast map=puertoRico at PERMANENT -o
> PNG: GRASS_TRUECOLOR status: TRUE
> PNG: collecting to file:
> /home/ivan/grassdata/pr/PERMANENT/.tmp/ivan-laptop/6771.0.ppm,
> GRASS_WIDTH=642, GRASS_HEIGHT=482
> g.pnmcomp in=6771.2.ppm mask=6771.2.pgm opacity=1.0
> background=255:255:255 width=642 height=482 output=6771.1.ppm
> GRASS_WIDTH=482, GRASS_HEIGHT=482
> background=255:255:255 width=482 height=482 output=6771.1.ppm
> g.region n=18.529654 s=17.874067 e=-65.218506 w=-67.957335 rows=4793
> cols=19279 nsres=15 ewres=15 tbres=1
> /home/ivan/grassdata/pr/PERMANENT/.tmp/ivan-laptop/6771.3.ppm,
> GRASS_WIDTH=642, GRASS_HEIGHT=154
> g.pnmcomp in=6771.5.ppm mask=6771.5.pgm opacity=1.0
> background=255:255:255 width=642 height=154 output=6771.4.ppm
> The problem is that the Map Display is in blank.
> If you want to try it, you can donwload the file from
> ftp://ftp.gap.uidaho.edu/products/Puerto_Rico/GISdata/Landcover/1_Land_cover_grid/
> the file is prgap_landcover.zip , and inside you will find the a .img
> file
> Here I add more Information:
> Spatial_Domain:
> Bounding_Coordinates:
> West_Bounding_Coordinate: -67.957335
> East_Bounding_Coordinate: -65.218506
> North_Bounding_Coordinate: 18.529654
> South_Bounding_Coordinate: 17.874067
> Spatial_Data_Organization_Information:
> Direct_Spatial_Reference_Method: Raster
> Raster_Object_Information:
> Raster_Object_Type: Pixel
> Row_Count: 4793
> Column_Count: 19279
> Vertical_Count: 1
> Spatial_Reference_Information:
> Horizontal_Coordinate_System_Definition:
> Planar:
> Map_Projection:
> Map_Projection_Name: Lambert Conformal Conic
> Lambert_Conformal_Conic:
> Standard_Parallel: 18.033333
> Standard_Parallel: 18.433333
> Longitude_of_Central_Meridian: -66.433333
> Latitude_of_Projection_Origin: 17.833333
> False_Easting: 200000.000000
> False_Northing: 200000.000000
> Planar_Coordinate_Information:
> Planar_Coordinate_Encoding_Method: row and column
> Coordinate_Representation:
> Abscissa_Resolution: 15
> Ordinate_Resolution: 15
> Planar_Distance_Units: meters
> Geodetic_Model:
> Horizontal_Datum_Name: North American Datum of 1983
> Ellipsoid_Name: Geodetic Reference System 80
> Semi-major_Axis: 6378137.000000
> Denominator_of_Flattening_Ratio: 298.257222
> Entity_and_Attribute_Information:
> Detailed_Description:
> Entity_Type:
> Entity_Type_Label: Layer_1
> Attribute:
> Attribute_Label: ObjectID
> Attribute_Definition: Internal feature number.
> Attribute_Definition_Source: ESRI
> Attribute_Domain_Values:
> Unrepresentable_Domain: Sequential unique whole numbers that are
> automatically generated.
> Attribute:
> Attribute_Label: Value
> Attribute_Definition: A number assigned to each specific land cover
> class or type.
> Attribute:
> Attribute_Label: Red
> Attribute:
> Attribute_Label: Green
> Attribute:
> Attribute_Label: Blue
> Attribute:
> Attribute_Label: Class_names
> Attribute_Definition: Land cover types
> Attribute:
> Attribute_Label: Opacity
> Attribute:
> Attribute_Label: Count
> Attribute_Definition: Number of pixels of each land cover type.
> Standard_Order_Process:
> Digital_Form:
> Digital_Transfer_Information:
> Format_Name: ERDAS
> Format_Version_Date: November 03, 2006.
> Format_Specification: This landcover was developed using ERDAS IMAGINE
> 8.7.
> Format_Information_Content: This raster dataset represent the
> landcover for Puerto Rico and it's adyacent islands.
> File_Decompression_Technique: no compression applied
> Transfer_Size: 0.000
> Thanks for your help! --
> Iván Henríquez
> _______________________________________________ grass-user mailing
> list grass-user at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-user
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
