[GRASS-user] Defining Environment variable for WinGRASS
Fri Apr 1 11:59:48 EDT 2011
Luisa Peña wrote:
> For instance if I define GDAL_DATA like that, If in the same script I run
> grass.Popen(<command to external gdal executable) is  that defined GDAL_DATA
> path applicable?
Yes.
