[GRASS-user] Problem with Python Scripts and grass.script	(GRASS
	6.5SVN) on Mac
    Johannes Radinger
    JRadinger at gmx.at
    Mon Apr  4 05:34:54 EDT 2011
Hello again,
as recommended I removed the python.org-python (and removed the lines to python.framework in the PATH.
When I now start python it is only the version 2.6.1 (also GRASS now uses this version) which should be the system-python. After removing the other python I recompiled the most recent version of GRASS 6.5, put my mapcalc-testscript into the bin folder and tried to run it both, from launch script and from the GRASS-Terminal. But there is still the same error:
GRASS 6.5.svn (gisdemo_ncspm):~ > testscript.py newmap=test elevation=elevation geology=geology
  File "/Library/GRASS/6.5/Modules/bin/testscript.py", line 54, in <module>
    sys.exit(main())
  File "/Library/GRASS/6.5/Modules/bin/testscript.py", line 47, in main
    grass.mapcalc("${newmap} = ${elevation} * ${geology}",
AttributeError: 'module' object has no attribute 'mapcalc'
Here some addtional info from within the GRASS Terminal:
echo "$PYTHONPATH"
/Applications/GRASS-6.5.app/Contents/MacOS/etc/python
my sys.path (in GRASS-terminal python) is:
['', '/Library/Frameworks/SQLite3.framework/Versions/3/Python', '/Library/Python/2.6/site-packages/numpy-override', '/Library/Frameworks/GDAL.framework/Versions/1.8/Python/site-packages', '/Library/Frameworks/cairo.framework/Versions/1/Python', '/Applications/GRASS-6.5.app/Contents/MacOS/etc/python', '/usr/local/lib/wxPython-unicode-2.8.11.0/lib/python2.6/site-packages', '/usr/local/lib/wxPython-unicode-2.8.11.0/lib/python2.6/site-packages/wx-2.8-mac-unicode', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python26.zip', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-darwin', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-mac', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-mac/lib-scriptpackages', '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-tk', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-old', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload', '/Library/Python/2.6/site-packages', '/usr/local/lib/wxPython-unicode-2.8.11.0/lib/python2.6', '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/PyObjC', '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode']
that is strange because there is no python.framework anymore so where does this come from?
The normal Terminal gives me for $PATH:
/opt/local/bin:/opt/local/sbin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/X11/bin
So maybe the sys.path is a hint for my problem...
/johannes
-------- Original-Nachricht --------
> Datum: Sun, 3 Apr 2011 15:27:41 -0700
> Von: Michael Barton <Michael.Barton at asu.edu>
> An: Johannes Radinger <JRadinger at gmx.at>
> CC: "grass-user at lists.osgeo.org" <grass-user at lists.osgeo.org>
> Betreff: Re: [GRASS-user] Problem with Python Scripts and grass.script	(GRASS	6.5SVN) on Mac
> When I and others have had a copy of Python from
> python.org<http://python.org> installed, it has usually caused problems, including bogus errors. I
> strongly advise against it. In theory, it should not be a problem, but in
> reality (in my experience) it IS a problem.
> I can't say for sure that this is where your problem lies, but I'd be
> suspicious. When you start python from the terminal, which one is it? How about
> from GRASS?
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> voice:  480-965-6262 (SHESC), 480-727-9746 (CSDC)
> fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Apr 3, 2011, at 12:23 PM, Johannes Radinger wrote:
> Hello Glynn,
> Hello Michael,
> the answers to your suggestions/questions below:
> Am 02.04.2011 um 17:24 schrieb Michael Barton:
> Have you installed Python from python.org<http://python.org/> on your Mac?
> If you have, there may be a problem with that.
> Yes I there is python2.6.6 from python.org<http://python.org/> installed
> but William Kyngesburye told me that this shouldn't be any
> Problem and GRASS GIS can handle this, but I am not sure. Maybe I've to
> try to deinstall it, but I don't know how excatly so that everything is
> removed correctly also in the libs.
> Michael
> C. Michael Barton
> http://csdc.asu.ed<http://csdc.asu.edu/>
> Am 03.04.2011 um 00:37 schrieb Glynn Clements:
> I tried to figure out the problem with william kyngesburye.
> the script is also working on his mac. I saved the script in the bin
> folder and ran in the GRASS terminal:
> What causes this AttributeError?
> The grass.script module is either broken or very old (the mapcalc()
> The GRASS build I've got is compiled from last weeks source (6.5)...
> function was added in December 2008).
> >From within GRASS, try the following:
> $ python
> > import grass.script as grass
> > print grass.__file__
> that is what I get... does that help you?
> /Applications/GRASS-6.5.app/Contents/MacOS/etc/python/grass/script/__init__.pyc
> > print grass.__path__
> and for the path:
> ['/Applications/GRASS-6.5.app/Contents/MacOS/etc/python/grass/script']
> /johannes
> Glynn Clements <glynn at gclements.plus.com<mailto:glynn at gclements.plus.com>>
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
NEU: FreePhone - kostenlos mobil telefonieren und surfen!
Jetzt informieren: http://www.gmx.net/de/go/freephone
