[GRASS-user] Problem with Python Scripts and grass.script	(GRASS
	6.5SVN) on Mac
    Johannes Radinger
    JRadinger at gmx.at
    Mon Apr  4 08:21:22 EDT 2011
So some additional information:
I tried now to run another simple script
including the r.thin command (with grass.run_command("r.thin",....)
and thats working perfectly...it seems that it is just a mapcalc
problem, but I still don't understand why its only a problem in my
case and not on your computers.
The normal mapcalculator works fine...its just a pyhton-script problem.
what should I do next?
/johannes
-------- Original-Nachricht --------
> Datum: Mon, 04 Apr 2011 11:34:54 +0200
> Von: "Johannes Radinger" <JRadinger at gmx.at>
> An: Michael Barton <Michael.Barton at asu.edu>
> CC: grass-user at lists.osgeo.org
> Betreff: Re: [GRASS-user] Problem with Python Scripts and grass.script	(GRASS	6.5SVN) on Mac
> Hello again,
> as recommended I removed the python.org-python (and removed the lines to
> python.framework in the PATH.
> When I now start python it is only the version 2.6.1 (also GRASS now uses
> this version) which should be the system-python. After removing the other
> python I recompiled the most recent version of GRASS 6.5, put my
> mapcalc-testscript into the bin folder and tried to run it both, from launch script
> and from the GRASS-Terminal. But there is still the same error:
> GRASS 6.5.svn (gisdemo_ncspm):~ > testscript.py newmap=test
> elevation=elevation geology=geology
> Traceback (most recent call last):
>   File "/Library/GRASS/6.5/Modules/bin/testscript.py", line 54, in
> <module>
>     sys.exit(main())
>   File "/Library/GRASS/6.5/Modules/bin/testscript.py", line 47, in main
>     grass.mapcalc("${newmap} = ${elevation} * ${geology}",
> AttributeError: 'module' object has no attribute 'mapcalc'
> Here some addtional info from within the GRASS Terminal:
> echo "$PYTHONPATH"
> /Applications/GRASS-6.5.app/Contents/MacOS/etc/python
> my sys.path (in GRASS-terminal python) is:
> ['', '/Library/Frameworks/SQLite3.framework/Versions/3/Python',
> '/Library/Python/2.6/site-packages/numpy-override',
> '/Library/Frameworks/GDAL.framework/Versions/1.8/Python/site-packages',
> '/Library/Frameworks/cairo.framework/Versions/1/Python',
> '/Applications/GRASS-6.5.app/Contents/MacOS/etc/python', '/usr/local/lib/wxPython-unicode-2.8.11.0/lib/python2.6/site-packages',
> '/usr/local/lib/wxPython-unicode-2.8.11.0/lib/python2.6/site-packages/wx-2.8-mac-unicode',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python26.zip',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-darwin',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-mac',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-mac/lib-scriptpackages',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python',
>  ks/Python.framework/Versions/2.6/lib/python2.6/lib-tk',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-old',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload',
> '/Library/Python/2.6/site-packages',
> '/usr/local/lib/wxPython-unicode-2.8.11.0/lib/python2.6',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/PyObjC',
> '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode']
> that is strange because there is no python.framework anymore so where does
> this come from?
> The normal Terminal gives me for $PATH:
> /opt/local/bin:/opt/local/sbin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/X11/bin
> So maybe the sys.path is a hint for my problem...
> /johannes
> > Datum: Sun, 3 Apr 2011 15:27:41 -0700
> > Von: Michael Barton <Michael.Barton at asu.edu>
> > An: Johannes Radinger <JRadinger at gmx.at>
> > CC: "grass-user at lists.osgeo.org" <grass-user at lists.osgeo.org>
> > When I and others have had a copy of Python from
> > python.org<http://python.org> installed, it has usually caused problems,
> including bogus errors. I
> > strongly advise against it. In theory, it should not be a problem, but
> in
> > reality (in my experience) it IS a problem.
> > I can't say for sure that this is where your problem lies, but I'd be
> > suspicious. When you start python from the terminal, which one is it?
> How about
> > from GRASS?
> > Michael
> > ____________________
> > C. Michael Barton
> > Director, Center for Social Dynamics & Complexity
> > Professor of Anthropology, School of Human Evolution & Social Change
> > Arizona State University
> > voice:  480-965-6262 (SHESC), 480-727-9746 (CSDC)
> > fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
> > www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> > On Apr 3, 2011, at 12:23 PM, Johannes Radinger wrote:
> > Hello Glynn,
> > Hello Michael,
> > the answers to your suggestions/questions below:
> > Am 02.04.2011 um 17:24 schrieb Michael Barton:
> > Have you installed Python from python.org<http://python.org/> on your
> Mac?
> > If you have, there may be a problem with that.
> > Yes I there is python2.6.6 from python.org<http://python.org/> installed
> > but William Kyngesburye told me that this shouldn't be any
> > Problem and GRASS GIS can handle this, but I am not sure. Maybe I've to
> > try to deinstall it, but I don't know how excatly so that everything is
> > removed correctly also in the libs.
> > Michael
> > C. Michael Barton
> > http://csdc.asu.ed<http://csdc.asu.edu/>
> > Am 03.04.2011 um 00:37 schrieb Glynn Clements:
> > I tried to figure out the problem with william kyngesburye.
> > the script is also working on his mac. I saved the script in the bin
> > folder and ran in the GRASS terminal:
> > What causes this AttributeError?
> > The grass.script module is either broken or very old (the mapcalc()
> > The GRASS build I've got is compiled from last weeks source (6.5)...
> > function was added in December 2008).
> > >From within GRASS, try the following:
> > $ python
> > > import grass.script as grass
> > > print grass.__file__
> > that is what I get... does that help you?
> /Applications/GRASS-6.5.app/Contents/MacOS/etc/python/grass/script/__init__.pyc
> > > print grass.__path__
> > and for the path:
> > ['/Applications/GRASS-6.5.app/Contents/MacOS/etc/python/grass/script']
> > /johannes
> > Glynn Clements
> <glynn at gclements.plus.com<mailto:glynn at gclements.plus.com>>
> > grass-user mailing list
> > http://lists.osgeo.org/mailman/listinfo/grass-user
> NEU: FreePhone - kostenlos mobil telefonieren und surfen!
> Jetzt informieren: http://www.gmx.net/de/go/freephone
