[GRASS-user] Re: Duplication of lines in output of r.profile.
    Hamish
    hamish_b at yahoo.com
    Wed Apr  6 00:54:39 EDT 2011
Marcello wrote:
> I solved it using:
> > d.where > map_profile
> instead of:
> > r.profile -ig input=map output=map_profile
> The only problem is that I can't see the points while I am digitizing.
use the middle mouse button with d.where to show the line.
> > I get many duplicated lines, some of which are not exactly duplicated,
> > but displace the coordinates by a very small distance, affecting also
> > the distance.
what version of GRASS? what kind of machine/OS?
how about if you trim off the 3rd,4th columns from what becomes the input
file?
Hamish
