[GRASS-user] Re: Duplication of lines in output of r.profile.
Marcello Gorini
gorini at gmail.com
Wed Apr 6 07:49:33 EDT 2011
>Marcello wrote:
>> I solved it using:
>> > d.where > map_profile
>> instead of:
>> > r.profile -ig input=map output=map_profile
>> The only problem is that I can't see the points while I am digitizing.
Hamish wrote:
>use the middle mouse button with d.where to show the line.
Yes, thanks, it helped. Then I can see the line after I digitize it, but the
good thing about r.profile is that you can see it WHILE you are digitizing,
so you can get your bearings better. But that's a minor problem anyway.
>> > I get many duplicated lines, some of which are not exactly duplicated,
>> > but displace the coordinates by a very small distance, affecting also
>> > the distance.
Hamish asked:
>what version of GRASS? what kind of machine/OS?
It's GRASS 6.4.0svn on a Linux Ubuntu 9.10, sorry not to have said it
before.
>how about if you trim off the 3rd,4th columns from what becomes the input
>file?
OK, so I tried this:
cat map_profile | cut -d' ' -f1,2 | r.profile -g input=another_map
output=another_map_profile --o
Was that what you meant? I get the same weird results, unfortunately.
Any other ideas?
Thanks for the help,
Marcello.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Duplication-of-lines-in-output-of-r-profile-tp6242694p6245727.html
Sent from the Grass - Users mailing list archive at Nabble.com.
