[GRASS-user] Python-Loop over points
Thu Apr 7 19:26:03 EDT 2011
Johannes Radinger wrote:
> Do you think that is the best way to loop over points..?
Only if the number of points is small. Otherwise, you're better off
putting them into a table and using a join.
