[GRASS-user] Python-Loop over points
Johannes Radinger
JRadinger at gmx.at
Fri Apr 8 04:45:42 EDT 2011
-------- Original-Nachricht --------
> Datum: Fri, 8 Apr 2011 00:26:03 +0100
> Von: Glynn Clements <glynn at gclements.plus.com>
> An: Johannes Radinger <JRadinger at gmx.at>
> CC: grass-user at lists.osgeo.org
> Betreff: Re: [GRASS-user] Python-Loop over points
> Johannes Radinger wrote:
> > Do you think that is the best way to loop over points..?
> Only if the number of points is small. Otherwise, you're better off
> putting them into a table and using a join.
What do you mean with your method (table and join)?
NEU: FreePhone - kostenlos mobil telefonieren und surfen!
Jetzt informieren: http://www.gmx.net/de/go/freephone
