[GRASS-user] replacement for d.mon in GRASS 7.0?
    alonso
    alonsarp at um.es
    Tue Apr 12 06:53:59 EDT 2011
I'm trying to use  ximgview for the first time but when I use this code:
d.erase
ximgview map.bmp &
d.rast mde
d.vect countries type=boundary
export GRASS_PNG_MAPPED=TRUE
d.vect erases the mde raster map (the same with type=centroids). It
draws what it is supposed to draw but erasing (covering?) the previous
layer.
I made a mistake or is ximgview just for simple stuff?
Is there any possibility of keeping d.mon in grass 7.0 to support old
scripts?
Thanks
El mié, 02-02-2011 a las 09:56 +0000, Glynn Clements escribió:
> Patrick_schirmer wrote:
> > Does someone know how translate previous display commands into GRASS70,
> > i.e. integrate a py-script that is called
> > "d.mon x1=start" (or similar) into GRASS70 doing these command:
> > #####start display in GRASS7.0
> > d.erase
> > ximgview map.bmp &
> It can't be done that way. A program (or script) cannot change the
> environment of its parent (e.g. the shell). This is why "export" has
> to be a shell built-in rather than a program.
> You could write a *shell* script which is "source"d rather than
> executed, or you could write a script which sets the environment
> variables then spawns a new shell.
> But the only way that a "d.mon" program could be made to work would be
> to change the drivers to read the settings from $GISRC rather than the
> environment.
> However, environment variables are more convenient for scripts and the
> GUI. Checking for environment variables first then $GISRC second would
> satisfy both use cases, but could be confusing for the user, as the
> $GISRC settings would be ignored if one of the environment variables
> was set.
