[GRASS-user] replacement for d.mon in GRASS 7.0?
Glynn Clements
glynn at gclements.plus.com
Tue Apr 12 16:49:10 EDT 2011
alonso wrote:
> I'm trying to use ximgview for the first time but when I use this code:
> d.erase
> ximgview map.bmp &
> d.rast mde
> d.vect countries type=boundary
> export GRASS_PNG_MAPPED=TRUE
> d.vect erases the mde raster map (the same with type=centroids). It
> draws what it is supposed to draw but erasing (covering?) the previous
> layer.
> I made a mistake or is ximgview just for simple stuff?
You need to set GRASS_PNG_READ=TRUE, but only once the image file
already exists, e.g.:
d.erase
export GRASS_PNG_READ=TRUE
ximgview map.bmp &
d.rast mde
