[GRASS-user] replacement for d.mon in GRASS 7.0?
    alonso
    alonsarp at um.es
    Wed Apr 13 02:00:39 EDT 2011
Ok. It works fine now thanks a lot.
Anyway this approach hasn't the flexibility and possibilities that
monitors had, like zoom, frames, queries (specially queries to several
maps with d.what.*).
I understand that python interface is an improvement, but I'd be happy
having d.mon in the all way in GRASS 7.
best wishes
Paco Alonso
El mar, 12-04-2011 a las 21:49 +0100, Glynn Clements escribió:
> alonso wrote:
> > I'm trying to use  ximgview for the first time but when I use this code:
> > d.erase
> > ximgview map.bmp &
> > d.rast mde
> > d.vect countries type=boundary
> > export GRASS_PNG_MAPPED=TRUE
> > d.vect erases the mde raster map (the same with type=centroids). It
> > draws what it is supposed to draw but erasing (covering?) the previous
> > layer.
> > I made a mistake or is ximgview just for simple stuff?
> You need to set GRASS_PNG_READ=TRUE, but only once the image file
> already exists, e.g.:
> 	d.erase
> 	export GRASS_PNG_READ=TRUE
> 	ximgview map.bmp &
> 	d.rast mde
