[GRASS-user] Raster addition
Moritz Lennert mlennert at club.worldonline.be
Thu Apr 14 08:15:06 EDT 2011
On 14/04/11 13:54, Martin Album Ytre-Eide wrote:
> Hello.
> I am trying to add some raster maps. I thought I could do this in
> r.mapcalc, but "new_map= old_1 + old_2" seems to produce a map where
> the maps overlap and ignoring areas where only on of the maps have
> values.
This is due to the way r.mapcalc handles NULL values. See the man page,
section NULL support for an explanation.
> I would like to do something similar to "v.overlay
> operator=or".
> Anyone who knows how to do this?
It depends on what you want the new map to contain as values. If you
want to add the value of old_1 to old_2 in places where they overlap,
one way would be to transform your null values to 0 using r.null null=
and then applying your formula.
If you just want a (any) value where one of the maps is non-null, then
you can use if. Something like this (untested):
new_map = if(!isnull(old_1) || !isnull(old_2), 1, null())
which should give you 1 where any of the two contains a value and a NULL
value elsewhere.
Moritz
