[GRASS-user] snap point to line/break line at given points
Daniel Victoria daniel.victoria at gmail.com
Sat Apr 16 11:25:30 EDT 2011
Not sure how to split and label the rivers but to snap the point to
the closest river you could use v.distance
Cheers
daniel
http://grass.fbk.eu/grass65/manuals/html65_user/v.distance.html
On Thu, Apr 14, 2011 at 6:36 AM, Johannes Radinger <JRadinger at gmx.at> wrote:
> Hello,
> I have a line-vector (river) and some points on that line. First I am straightening that line with v.generalize (method: boyle). Now, there is the problem that the points are not exactly on the line anymore. So I want to snap (move) the points to the new generalized line again. Which tool is able to do that?
> After that I want to split the line at these points and want to give the attribute value to the newly created segments. These segment values should represent the number/value of the upstream point (which was used to split). How can this be done in GRASS?
> Do you have any ideas to solve these two problems/challenges?
> thank you
> /johannes
> GMX DSL Doppel-Flat ab 19,99 Euro/mtl.! Jetzt mit
> gratis Handy-Flat! http://portal.gmx.net/de/go/dsl
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
