[GRASS-user] special python expressions in v.distance
    Johannes Radinger
    JRadinger at gmx.at
    Thu Apr 21 06:27:27 EDT 2011
Hello,
I want to use v.distance in a pyton script.
I try:
    grass.run_command("v.distance",
                      flags="o",
                      from="points",
                      to="line",
                      upload="to_x,to_y",
                      col="to_X,to_Y")
but I fail because the expression FROM is already
used by python...
what is the correct way to handle that problem?
thank you in advance
/j
NEU: FreePhone - kostenlos mobil telefonieren und surfen!
Jetzt informieren: http://www.gmx.net/de/go/freephone
