[GRASS-user] special python expressions in v.distance
Glynn Clements
glynn at gclements.plus.com
Thu Apr 21 07:56:29 EDT 2011
Johannes Radinger wrote:
> I want to use v.distance in a pyton script.
> I try:
> grass.run_command("v.distance",
> flags="o",
> from="points",
> to="line",
> upload="to_x,to_y",
> col="to_X,to_Y")
> but I fail because the expression FROM is already
> used by python...
> what is the correct way to handle that problem?
Add a leading underscore:
_from="points",
If the first character of a keyword is an underscore, it's removed
when generating the argument list. This allows passing arguments which
are Python keywords or which are recognised by the run_command()
function.
Most arguments which are recognised by the Popen() constructor are
passed to Popen() rather than to the program. The argument names
"flags", "overwrite", "quiet" and "verbose" are also treated
specially.
