[GRASS-user] running Python script in grass
    Johannes Radinger
    JRadinger at gmx.at
    Tue Apr 26 07:01:06 EDT 2011
Hello
Put the script into the bin folder of your GRASS libary (the place where the add-ons are also stored)
Then you can start them in the Command Console of GRASS with
"scriptname.py", assuming that you've set the script options (#%) correctly.
/johannes
-------- Original-Nachricht --------
> Datum: Tue, 26 Apr 2011 12:52:45 +0200
> Von: Soeren Gebbert <soerengebbert at googlemail.com>
> An: vinod kumar <nani.kunithi at gmail.com>
> CC: grass-user at lists.osgeo.org
> Betreff: Re: [GRASS-user] running Python script in grass
> Hello,
> the grass wiki will help you:
> http://grass.osgeo.org/wiki/GRASS_and_Python
> Cheers
> Soeren
> 2011/4/26 vinod kumar <nani.kunithi at gmail.com>:
> > Hi all,
> > How to run a python script in grass.
> > Thanks in advance,
> > nani.
> > grass-user mailing list
> > http://lists.osgeo.org/mailman/listinfo/grass-user
NEU: FreePhone - kostenlos mobil telefonieren und surfen!
Jetzt informieren: http://www.gmx.net/de/go/freephone
