[GRASS-user] running Python script in grass
vinod kumar nani.kunithi at gmail.com
Tue Apr 26 07:10:48 EDT 2011
Hi Johannes, Soeren Gebbert,
Thanks for the information. Is there any Editor so that i can easily write
code.
Thanks,
nani
On Tue, Apr 26, 2011 at 1:01 PM, Johannes Radinger <JRadinger at gmx.at> wrote:
> Hello
> Put the script into the bin folder of your GRASS libary (the place where
> the add-ons are also stored)
> Then you can start them in the Command Console of GRASS with
> "scriptname.py", assuming that you've set the script options (#%)
> correctly.
> /johannes
> -------- Original-Nachricht --------
> > Datum: Tue, 26 Apr 2011 12:52:45 +0200
> > Von: Soeren Gebbert <soerengebbert at googlemail.com>
> > An: vinod kumar <nani.kunithi at gmail.com>
> > CC: grass-user at lists.osgeo.org
> > Betreff: Re: [GRASS-user] running Python script in grass
> > Hello,
> > the grass wiki will help you:
> > http://grass.osgeo.org/wiki/GRASS_and_Python
> > Cheers
> > Soeren
> > 2011/4/26 vinod kumar <nani.kunithi at gmail.com>:
> > > Hi all,
> > > How to run a python script in grass.
> > > Thanks in advance,
> > > nani.
> > > _______________________________________________
> > > grass-user mailing list
> > > http://lists.osgeo.org/mailman/listinfo/grass-user
> NEU: FreePhone - kostenlos mobil telefonieren und surfen!
> Jetzt informieren: http://www.gmx.net/de/go/freephone
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110426/9824b807/attachment.html
