[GRASS-user] running Python script in grass
    Johannes Radinger
    JRadinger at gmx.at
    Tue Apr 26 07:33:17 EDT 2011
Just look at:
http://wiki.python.org/moin/PythonEditors
There are many!
I use Textwrangler on my Mac and before the
standard IDLE editor.
/johannes
-------- Original-Nachricht --------
> Datum: Tue, 26 Apr 2011 13:10:48 +0200
> Von: vinod kumar <nani.kunithi at gmail.com>
> An: Johannes Radinger <JRadinger at gmx.at>
> CC: grass-user at lists.osgeo.org
> Betreff: Re: [GRASS-user] running Python script in grass
> Hi Johannes, Soeren Gebbert,
> Thanks for the information. Is there any Editor so that i can easily write
> code.
> Thanks,
> nani
> On Tue, Apr 26, 2011 at 1:01 PM, Johannes Radinger <JRadinger at gmx.at>
> wrote:
> > Hello
> > Put the script into the bin folder of your GRASS libary (the place where
> > the add-ons are also stored)
> > Then you can start them in the Command Console of GRASS with
> > "scriptname.py", assuming that you've set the script options (#%)
> > correctly.
> > /johannes
> > > Datum: Tue, 26 Apr 2011 12:52:45 +0200
> > > Von: Soeren Gebbert <soerengebbert at googlemail.com>
> > > An: vinod kumar <nani.kunithi at gmail.com>
> > > Hello,
> > > the grass wiki will help you:
> > > http://grass.osgeo.org/wiki/GRASS_and_Python
> > > Cheers
> > > Soeren
> > > 2011/4/26 vinod kumar <nani.kunithi at gmail.com>:
> > > > Hi all,
> > > > How to run a python script in grass.
> > > > Thanks in advance,
> > > > nani.
> > > > _______________________________________________
> > > > grass-user mailing list
> > > > http://lists.osgeo.org/mailman/listinfo/grass-user
> > NEU: FreePhone - kostenlos mobil telefonieren und surfen!
> > Jetzt informieren: http://www.gmx.net/de/go/freephone
GMX DSL Doppel-Flat ab 19,99 Euro/mtl.! Jetzt mit
gratis Handy-Flat! http://portal.gmx.net/de/go/dsl
