[GRASS-user] Re: how to only fill small sinks with r.fill.dir
Saber
razmjooeis at faunalia.co.uk
Tue Apr 26 12:04:33 EDT 2011
Here is a (not a very quick) solution I can think of:
1- Create an inverse mask
2- convert the mask to vector (r.to.vect)
3- clean the vector file to get rid of the areas not required (v.clean)
4- convert the vector back to raster (v.to.rast)
5- Use the new raster as a mask for filling holes (probably you need step
4.5 to slightly buffer the raster)
Hope that helps
> Any ideas on this?
> Bryan
> On Mon, Apr 18, 2011 at 14:49, Bryan Keith <bkeith at itascadenver.com>
> wrote:
>> Hello,
>> Is there a way to only fill sinks in a DEM if they are smaller than a
>> certain tolerance? I have a couple areas of internal drainage that
>> really are correct (and quite large), and I have a quite few small
>> sinks that are incorrect and artifacts of the interpolation. Any
>> ideas how to this? r.fill.dir attempt to fill all the sinks.
>> I'm trying to improve the results from r.flow Too many tracks end in
>> small holes where I'd like them to continue downstream. Thanks.
>> Bryan
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
