[GRASS-user] Re: how to only fill small sinks with r.fill.dir
Bryan Keith
bkeith at itascadenver.com
Tue Apr 26 12:18:33 EDT 2011
Hmmm, I'm not following all your steps, but I don't want to manually
identify valid sinks vs. invalid sinks. I have quite a lot of
surfaces to process, and I'm happy to fill all sinks except those
deeper than 10m.
On Tue, Apr 26, 2011 at 10:04, Saber <razmjooeis at faunalia.co.uk> wrote:
> Here is a (not a very quick) solution I can think of:
> 1- Create an inverse mask
> 2- convert the mask to vector (r.to.vect)
> 3- clean the vector file to get rid of the areas not required (v.clean)
> 4- convert the vector back to raster (v.to.rast)
> 5- Use the new raster as a mask for filling holes (probably you need step
> 4.5 to slightly buffer the raster)
> Hope that helps
>> Any ideas on this?
>> Bryan
>> On Mon, Apr 18, 2011 at 14:49, Bryan Keith <bkeith at itascadenver.com>
>> wrote:
>>> Hello,
>>> Is there a way to only fill sinks in a DEM if they are smaller than a
>>> certain tolerance? I have a couple areas of internal drainage that
>>> really are correct (and quite large), and I have a quite few small
>>> sinks that are incorrect and artifacts of the interpolation. Any
>>> ideas how to this? r.fill.dir attempt to fill all the sinks.
>>> I'm trying to improve the results from r.flow Too many tracks end in
>>> small holes where I'd like them to continue downstream. Thanks.
>>> Bryan
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
