SV: [GRASS-user] Some questions about d.vect and d.rast
Martin Album Ytre-Eide
Martin.Album.Ytre-Eide at nrpa.no
Fri Apr 29 03:45:42 EDT 2011
My way of using d.vect and d.rast in a python script is by first setting some variables and then using d.mon with the png driver:
os.putenv(GRASS_PNGFILE,'%s/%s.png' % (dirname,filename))
os.putenv(.....
grass.run_command('d.mon', start='PNG')
grass.run_command('d.rast',....
grass.run_command('d.vect',...
grass.run_command('d.mon', stop='PNG')
#If you want to display your map right away you could end your script with something like:
os.system(eog '%s/%s.png' % ((dirname,filename)) #linux eyes of gnome (eog)
Hope this helps.
Martin
-----Opprinnelig melding-----
Fra: grass-user-bounces at lists.osgeo.org [mailto:grass-user-bounces at lists.osgeo.org] På vegne av Hamish
Sendt: 29. april 2011 00:38
Til: grass-user at lists.osgeo.org; Johannes Radinger
Emne: Re: [GRASS-user] Some questions about d.vect and d.rast
Johannes wrote:
> First I've two general questions about d.vect:
> 1) Is it possible to use own symbol for the point icons?
see
http://grass.osgeo.org/wiki/IconSymbols#Authoring_instructions
> 2) How can I change the line type (e.g dashed line, etc.)?
You can't. (only in ps.map)
Maybe it will be possible in grass7?
> I also want to use d.vect and d.rast in a python script after some
> other calculations but the maps aren't displayed in the running
> display-window.
I'll leave that for others to answer.
Hamish
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
